Outside door handle rod
sirweesarunch
Oceanside
Classic Industries sells them , Huntington Beach Ca. I bought a 1/2 dozen from them. You push the clip down on the part that has the two holes you mentioned. The tang on the clip goes in the lower hole and the upper hole aligns with upper part of the clip. Then you push the rod through the upper hole and it goes all the way through , the back side of the clip snaps into the groove on the end of the rod .. click and its done. Very easy. Much harder to remove. To remove you have to pry the lower tang out of the hole and slide the clip up where the clip will slip past the groove in the rod releasing it to pop back out of the hole.
Does someone need Oe parts
Mark80K15
Sicamous, BC
Mark
K15
I thought this issue couldn't be more painful than the install I went through. Thanks for the update Mr. Super Moderator.
Hi all, thanks in advance for your help. I have a 80 GMC K15 and the drivers outside door handle does not open the door. The door opens fine using the inside handle. I removed the door trim pad and found that the outside door handle rod is just hanging from the handle. It is no longer attached to the lock mechanism. So I have some questions:
1) According to the 1980 GMC Service Manual page 2D-15, Fig. 2D-37 (below) shows a retaining clip where the rod inserts into the lock mechanism. I don't have the clip at all. Anyone know where I can get one? I should get a new rod too as this one might be a little bent.
2) There are actually 2 holes in the lock mechanism where the rod can be inserted. They are vertically aligned, with one above and one below. Anyone know which one should be used?
3) Any advice on how to install the rod and clip to the lock mechanism? I ask because it is a very tight space and I can't really get my hands in there. Do I use very long nose pliers to hold on the clip, and then shove in the rod with, say, needle nose vice grips?
Thanks, Mark
I very likely have a lot of those clips if you want me to look
Mark80K15
Sicamous, BC
Mark
K15
Thanks anyway AuroraGirl, I'll stick with the Mickey Mouse solution for now. And sirweesarunch says I can get them from Classic Industries. And thanks for the advice sirweesarunch.
350 w/203
You certainly went thru a lot to get a decent looking (and working) Mickey Mouse job! Well done!
Mark80K15
Sicamous, BC
Mark
K15
Aw thanks, Snoots! I needed that.
My78truck
'Ol Holly
Virginia
Becky
C10 Silverado
5.7L
Great job Mark80K10!!! I just got done replacing my exterior doors handles also. What a frustrating PIA. Narrow, cramped, dark working environment. Went out and bought a long, skinny, flashlight with magnet from Harbor Freight. Made things better in the light area. I would recommend this light for anyone. It is not only skinny to get into tight areas, but has a light on the tip, a magnet on the other end and tip folds and swivels how ever you need it. The clip is a serious PIA, especially if it falls off. :mad:
Mark80K15
Sicamous, BC
Mark
K15
Hi My78truck, thanks for the tip. Mark
tadslc
Birmingham, AL
Tad
350 Blueprint
I know this is an old thread but having just dealt with this yesterday I had to include this video I found that actually helped me get through the process.
I don't know what GM was thinking with this design.
Randy and Easton
North Richland Hills, Texas
Randy
C-10 LWB
@Mark80K15 , we had similar issues and did not want to wait on shipping on the actual white clip so I drilled a small hole in shaft of the arm and inserted it into mechanism and put a small washer and cotter pin… and it’s been fine ever since… did replace the other with the actual white part before door panel last week…
Randy and E
Doppleganger
OH-MI: Just like it sounds
I get to do this shortly as everything is out of my doors. This is one of those areas I'd love for @Keith Seymore to chime in on as to how they originally assembled these things. Were they assembled on a table and then fished inside the door? Quite a game of finger-Twister inside of 4" with little to no visibility.
Moderator Administrator
This is probably the part of a squarebody that I dislike the most. Space is super tight in there and my fingers just don't like to contort the way they need to when trying to do this job. Especially on the rear doors of a burb or 3+3. Those rear doors are about 100x worse than the regular doors :whymewhyme:
Doppleganger
Older Volvo, Benz or Jag sedans had these same type of multiple rods, with the keepers all being 50+ yr old plastics. They were bad enough but very doable (most fun was when they'd come off and the door wouldn't open from either inside or out). These squares seem to have more rods to them and more areas that are totally blocked from view.
If they could be assembled on a table and then fished inside....I'd be all in for finding out how.
Mark80K15
Sicamous, BC
Mark
K15
Thanks for the video, tadslc. It adds to the knowledge in this thread. I'm still good with my bailing wire fix, two years ago.
WyldTinker
