Old77’s GMT400 SWB 4x4 5-speed project/DD
Moderator Administrator
Braver than me! Looks like you need a roof patch too though. :shrug:
:slap: yep…..one thing at a time, fella. That’s far less involved than this deal. For a non-professional like myself, this is a skill stretcher! :lol: that other area above the window will be much simpler to repair.
Moderator
Imho, it ain't a show rig... just metalwork it a little smoother, grind it and slather some Duraglass on it. Then mudwork it and prime/paint and then pretend nothing ever happened.
As minor as that is, that thought has entered my mind for that small spot. If this corner wasn’t so major, that coulda been done there, too, but it was way too far gone to consider that as a fix in my mind :)
Before lunch I went and scrapped the bed. 300 lbs of metal got me $13.37 :hmm: how do people make anything scrapping metal??? I spent more on gasoline to get there lol
Also, got the patch mostly in before lunch. I had to cut a slit in it to make the door gap better (you know, cuz show truck #gamechanger :happy175: ). After lunch is finishing up welding that cut and the inside of the door then body work this afternoon. Body work won’t take long at all. Then tonight after dinner or tomorrow afternoon I’ll get a couple of my kids to lend a hand with the rear window install
legopnuematic
Licensed Junk Dealer
MO
Spencer
That’s like 4.5¢/lb or $90/ton. When I scrapped the red dodge cab and bed I got 6.5¢/lb or $130/ton.
Looking good though.
Well, here she is for now. Overall, I’m very happy with the results. I didn’t realize until I started fitting up the patch piece that there was also a dent in the body line. So I had to draw a line and leave things for “next time”. There’s also a small dent down below the body line that I knew was already there. So round two of body work at some point in the future will handle those things :popcorn:
BEFORE
AFTER
That dent at the bodyline is in the perfect spot, just get a flat punch and continue the bodyline back all the way around the corner :crazy:
Something like that :lol: I’m actually going to cut it, tap with body hammer and such to the shape it as needed, weld it and grind it and that should bring it back around decently. It just won’t be today or this weekend :)
Oh and @89Suburban can lick a salty d|ck :crazy:
Moderator
I've never wasted time with scrap sheet steel. I've always just let a buddy take it or I just dump it in the scrap pile at work.
Now batteries on the other hand... I collect those cores. I'll put each one on a charge cycle and see if it comes back to life. I often wind up with free batteries for my vehicles. The junk batteries get stockpiled until I haul them in. Just this morning I actually hauled in a bunch to the local scrap yard, got $172.
Rear window installed
Ball joints on the other hand….. :flipthebird:
Have about 4 hours into it at this point and still have the lower to do :mad:
bluex
Spartanburg SC
C15
Is that a fancy power slider I see?
The riveted joints suck. I usually drill all the way through them, grind the head off then air hammer them out. That's if I cant talk them into replacement arms anyhow. 4x4 lowers are tough to get too though
Manual slider but seems like a pretty nice unit. I’m happy with it :)
Yes, it completely sucks! I was very surprised when I learned that they don’t sell lowers filled with new ball joints and bushings. At that point, I just resigned myself to the fact I was in it for the long haul. And I’d tried the same method you said works and that didn’t work with these uppers. The rivets have essentially become one with the control arm :( so I’m having to completely drill through the rivets and knock off the heads so that the bolts for the new ball joints have a place to go.
Worked another 4 hours on them today. The upper is all but ready to install with the exception of one hole. It will NOT drill :mad: So it continues to hang out there and I attacked the lower ball joint. I got all 4 drilled through so just a little more work and that lower ball joint will be wrapped up. I’ll get that finished tomorrow after work and then attack that last hole on the upper again. It’s pissing me off!! LOL I even tried heating it to see if I could beat it out after applying a crap ton of heat. Nope……so back to fruitless drilling I went :banghead:
I’ve got 3 evenings to get the ball joints done before I go in for inspection and then licensing it.
Nborden88
