Nylon cam gear years
77Dmax
vt
Joe
Please post an update as to how well the clutch functions along with a part number. I've replaced several before and usually they don't disengage.
ASPEC
C2500
Hayden 2797 severe duty. I will post an update as soon as it has enough in service time.
ASPEC
C2500
Make sure when using a heavy duty or severe duty fan clutch that your fan is compatible. If your fan is has less than a 3" blade or not enough pitch it will not produce enough drag to disengage the clutch and may not pull enough air to cool the clutch.
Moderator
Well dang, that's something that I have not ever considered.
How much pitch would you say is needed for a "severe duty" type clutch? Generally speaking, of course.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
ASPEC
C2500
Here is some info from Hayden:
All fan clutches are for specific applications and should be applied only on the vehicle for which they are cataloged. Use of the incorrect fan clutch may result in poor cooling, excessive noise, reduced fuel economy or fan clutch failure.
• Standard Duty Thermal: Turns the fan 50-60% of shaft speed when engaged. Used with fans with lighter pitch (1-1/2" of pitch). Flat plate impeller design with 30 sq. in. of working surface.
• Heavy-Duty Thermal: Turns the fan 80-90% of the shaft speed when engaged for increased cooling. Used with deeper pitch fans (2 1/2" of pitch). Land and groove design with 47 sq. in. of working area allows higher operating RPM's.
• Severe Duty Thermal: Turns the fan 80-90% of the shaft speed when engaged. Used with deeper pitch fans. (2- 1/2" of pitch). Land and groove design with 65 sq. in. of working area. Larger working surface provides cooler running and longer life expectancy.
heres what I know about these two fans:
The 3 blade is from my 1980 k25 gmc with a manual transmission and no AC
The 7 blade is from a 1978 k10 with an automatic transmission, an auxillary engine oil cooler, high capacity cooling system (big rad), and AC
The clutches , i frankly dont have anyway to verify if they are from each application originally or not
hauto85
