new from arkansas with custom speaker boxes
sparky1973
pea ridge arkansas
aaron
Hey guys just wanted to let people know that we are starting to make custom speaker boxes that fit behind the seat. We can put almost any speaker size combos in these boxes. The one I'm posting a pic of is made for two 6x9 and one 10" sub. If anyone would be interested u can contact me at 479-212-2125 by txt, again we are based out of Arkansas. Thanks guys
350runner
tx
Ceasar
What's the price on your boxes?
sparky1973
pea ridge arkansas
aaron
Depends on what speakers u want inside as in size. If that makes sense. We don't include speakers but we will need to know what speaker sizes u want.
350runner
tx
Ceasar
Price for (2)12 or(2)10 inch subs?
sparky1973
pea ridge arkansas
aaron
$125, that includes being done where all u have to do is install the speakers and that includes shipping.
350runner
tx
Ceasar
That's a very good deal! I'm sure you'll get some request.
NternalFriction
Center Ridge
Charlie
Scottsdale C10
I may holler at ya about one. Thinkin 2 6 1/2's and a 10. Where you located. I see 479 area code, I'm in the 501 area.
sparky1973
pea ridge arkansas
aaron
I'm in northwest Arkansas by Bentonville or Fayetteville
:welcome: from N.E.
Mobius
Fayetteville, AR
c10 Heavy Half
350 SBC
Would your box be able to accommodate a JL Audio 10W3? It's a 10" sub with a 6" mounting depth. The magnet is pretty massive. The net internal volume should be about .625 cu ft, sealed. Also, I'm in Fayetteville. What would the cost be if I could pick it up, instead of shipping it? Thanks.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Sound would be much better if your speaker boxes were made from mdf and not plywood. Plywood resonates sound very poorly. Not meaning to bust your balls...but I have been making custom speaker boxes and sub enclosures for the past 15 years. Looks like you have a good start. The important part as always is having the correct airspace for the speakers per manufacturer specs. Proper porting is also important as well. Good luck with your project. Looks like you're off to a good start.
smoothandlow84
Steve
The angle of that box doesn't look correctt for the angle of a bench seat ( if you want to match the angle of the oem bench seat). I have a pair of 2 ohm JBL12's behind my bench seat that are 6.25 inches deep. The width of my enclosure is 3-1/2" at the top and close to 8 inches wide at the bottom and 4' long. If you make a template of the space available behind your bench seat when reclined and in the position needed when you drive...you'll be able to tell how deep your box can be in order to accomodate your speaker depth. Slim mount speakers are the best if you need extra leg room in order to drive. I'm 6-1" and have just enough room with my enclosure to drive comfortably.
Mobius
Fayetteville, AR
c10 Heavy Half
350 SBC
Thanks For the info. I'll do some measuring and figuring this weekend.
aaron06
