Need Quadrajet related emissions parts for smog
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I need a couple of parts to make my truck smog compliant for California. I need the Solenoid vacuum control valve (Part #4 in the first photo) as mine has a nipple broken off broken. On big blocks it is mounted to the thermostat housing. I also need the Throttle lever actuator (Part #1). It's mounted on the driver's side front of the carb. I know these parts are common to 81-85 454's and 350's with a 4 speed. I figure someone may have a truck sitting around in a non-smog state that doesn't need these parts. Thanks for your help.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I got lucky and found someone parting out a 454 from a motorhome. I thought if anyone ever needs the part numbers, here they are:
Part #1 -Throttle lever actuator - Rochester 57174
Part #4 - Solenoid vacuum control valve - GM 1997479
Hard
