need help with paint
87Jimmy
Grand Rapids
k5
well I am in need of some help, I am wonder how much paint you think i will need I have the truck in white primer sealer because i am going with an old syle paint job ill try to post a pic of what im thinking. im going with hugger orange and white 2 tone. I know i need to paint the whole truck white first and then lay down the orange. i am doing 2 stage paint. i am also painting the interior.
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
it all depends on what style 2 tone you are doing but i would paint the stripe color first mask it then paint the rest of the body then pull the masking and clear coat it
its easier to mask the stripe then it is to mask the whole truck
i would buy a gallon of white base coat usally reduces 1 part paint to 1 part reducer 1 gallon should give you more than enough to paint inside and out even in the bed
and a quart of orange would give you 2 after reduceing it
and most clear coats if i remember are a 4 to 1 to 1 clear/hardener/reducer a gallon should be enough for your truck
i like to have more then i need so i don't run out in the middle of a paint job so i might be telling you to much but not by much
and the mixing ratio may be different by manufacture of the paint you buy
88V30
