Need advise.
paulrowe
Ontario, Canada
I'm using a zinc anode plug in the block to counteract that problem.
I must counter.
While I realize what you are doing is well and good intentioned, it is always best to use brass freeze plugs wherever they are on a rebuild.
The only steel or zinc-coated plug that should be on the engine is the cam plug.
73c20jim
Tombstone, AZ
Why???
No corrosion at all, ever.
Have you ever had to change a freeze plug without going through a lot of headache?
73c20jim
Tombstone, AZ
Actually no.
GMblood
