- Apr 11, 2017
- kansas
- Rick
- c20
Well I stretched that tire open used 3 spray paint cans spaced at 12/4 and 8 mounted it back up still had to ratchet strap it but it worked. Now just for fun I bolted a center mount bar from a coats 40 40 to a piece of unistrut I had laying around. Ignore the strap hook I just used it as washer. Anyway it works awesome for mounting,so if you have access to a coats center post bar bolt it to some square stock or copy the mount end. So to date I've done a duckbill on a stick,a lucid mod, tried to mod the harbor freight bar,got a coats tireman bar and used a coates 40 40 bar. Most bang for the buck is the 40 40 bar
