- May 18, 2020
- The Right side of Washington
- Todd
- K20, C10
D load radials will take the tires out of the equation. That said, if you think it’s the tires making it handle poorly that is largely how much they flex. You can do an easy test and air up your current tires to whatever pressure you think will cure the problem and try it out.Oh I know the two are unrelated. I was just connecting the dots on paper that I currently have load range C bias play tires that, other than longevity, I’m not happy with. That said, I’m thinking that a load range D, radial tire might be what fits my needs better.
I used the same logic to figure out what truck tires I needed, and ended up getting p rated highway tires that I’ve been super happy with. Turns out buying stuff based on specs that meet your honest needs works out way better than buying tires that look cool. Who knew.
They won’t explode. And then you’ll know.
