Modify windshield spray
Camar068
Air Force Supporting Member
10 yrs Air Force
The spray on my wipers suck. Has anyone installed newer type nozzles that would be located on the cowl screen area like newer vehicles? With winter coming up it would be nice to have a nice spray on the whole windshield at once to help clear frost....and now's the time to do it.
Thanks In Advance
'Maro
nvrenuf
Mobile, Al.
Get some mid 80’s+ arms with sprayers at the wiper blade.
Camar068
10 yrs Air Force
right....thats what I got now....they suck
Moderator
They may be fouled? GM's "wet arm" wiper system normally works well. They used it for a long time.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
The round eyes had nozzles that peek up through the cowl, which you could emulate that setup, but yours are likely clogged up. I like the wet arm better than the fixed mount ones myself. The clunkier ones tend to get brittle, and I’ve broken them not being careful when I’m trying to clean. What I do when that happens is take a hypodermic needle and syringe with water and back flush the nozzles. You can literally see the packed in crud come out the other end. Then they work good as new.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Huh? Mine poke up through the cowl. There are reliefs in the firewall and screw in with clips into the firewall.
What are these wet arm wipers you speak of?
Maybe the cucvs didn’t get the newer 80s tech... mine are like what Jesse is describing for the round eyes.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The cutoff for the nozzles in the cowl was 84, 85 they went to the nozzles mounted on the arms.
Camar068
10 yrs Air Force
Thanks guys....I'll try cleaning them first.
Camar068
10 yrs Air Force
tightened up the hoses and she's doing better. I'll get some vacuum line and replace them soon as they are almost guitar strings now lol.
While I was there I noticed the jug was leaking fluid when almost full. This is the 2nd time I've had to repair it. I broke apart a snuff can and used the plastic to fill the crack in with a soldering iron. Before I had melted the crack then pushed the melted plastic back into the crack. Thought a little more liquid plastic won't hurt.
Quick brush to the iron to get the plastic off it.
Thanks Guys, good to know there was an option for a sprayer in the cowl.
Jeremy89
