Mastercraft 31's or 32'
Camar068
Air Force Supporting Member
Kentucky
10 yrs Air Force
back to the drawing board, wish I'd noticed it last night. Only the MXT is available in 32x11.5/15. Grrrr....lol. Guess I'll be looking at other brands to compare.
More questions to come I'm sure. Thx guys.
MXT:
Camar068
Kentucky
10 yrs Air Force
Falken any good? It's either go back to 31.x10.5 or go with Falken Rubitrek A/T 32" for $200 more.
Thanks Guys.
[Edit] The falken 32's tread is 19mm with load of 2,535 VS Mastercraft Courser Trail HD 31" 13mm with load of 2,270
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Thanks Guys.
Falken makes decent tires. An aggressive A/T should be over 16/32” tread depth new. I think I’ve seen a few that are 15/32”…
Never heard anything about the Rubitrek, but the AT4W is pretty well rated.
Moderator
Yeah, I've never had a Falken tire that I didn't care for. Not that I can remember anyway.
Camar068
Kentucky
10 yrs Air Force
how are the AT4W on the interstate/daily driver?
Moderator
I just remembered that it was Falkens we put on 3 of the work trucks very early this year. Two sets of the Wildpeak AT that @Frankenchevy spoke of, and also a set of the Wildpeak RT's. They are absolutely fantastic tires for muilti-purpose trucks. The RT's are slightly more aggressive, but still wear well and really aren't any louder on the pavement.
Nearly 15k on all three sets now, I believe.
Camar068
Kentucky
10 yrs Air Force
Future reference the MC's lasted just over 5 years with my driving.
The Falkens feel great....maybe better than the MC's. Time will tell, and hopefully document here.
The Right side of Washington
Ya I always hone in on tread depth too. More is better…for obvious reasons.
What I’ve seen is many tire models may have 15-16/32 in the XL load versions but when you step up to LT tires the tread depth goes up to 17-19/32 sometimes.
When comparing price difference between identical XL and LT tires it often isn’t much $. And if you’re buying them for the long haul, on a lighter vehicle (midsize or half ton) they will last MUCH longer. More than just the extra couple 32nds of tread depth would provide. They’re generally also a harder compound rubber (a 1 ton diesel would eat the softer rubber for lunch) which adds alot to tire life on a lighter weight vehicle.
Now it also reduces traction a bit apples to apples. But that is easily rectified with a bit lower tire pressure in the wet/snow season or if that’s not enough, siping the tires will soften them up a good amount without measurably reducing tread life.
Best snow tires I’ve had (short of actual snow tires) on any truck but speaking for light trucks 1/2 tons is a set of LRE all terrains (fill in your favorite model of tire), siped all the way across (or even just inside treads) and drop the tire pressure to around min safe. And the stiffer side walls compensate a little for the lower pressure.
Agreed. And as evidence, their increasing popularity. Seems 5-10 years ago ish, Falkens were a fair bit less costly than the “big names”. Now last I looked they’re about the same price. Means they sell a lot of them.
UNCLECHAD2021
