Jays86
- Jun 26, 2016
- Sacramento, CA
- Jason
- K10
Ok, I'm sure this thread had been beat to death, but I have a few questions on which route to go with my truck. I have an '86 K10, 5.7, 700r4, 10k on the engine and it has an Elgin E923P cam, 3" flowmaster, MSD replacement distributor still connected to the factory ECM, but all stock otherwise. I just had the carb completely rebuilt AND rebushed because the shafts had some play, so it's running pretty good otherwise. It does fall on it's face a bit with the A/C on, but I'll get that part fixed. It also seems to have a radiator leak near the bottom hose, but it only seems to leak after turning the truck off and when I had the A/C on. It's a daily driver, I may take it on some trails once in a great while, I may tow with it once in a great while, but it's a daily driven city/highway driver. My main question is, what gears to run? According to the build sheet, it has 3.08's, but I want to confirm that by lifting it and counting the revolutions. It obviously came with 235/75/15's according to the build sheet, but currently has 32x11.50x15's on it. Unfortunately, the tires have a ton of tread, but the truck sat for a while and the tires are now so dry that I can see the steel belts. I'll most likely stick with the same size that's on there now, but I was wanting to lift the truck a little, and go to a 33" or a 35" tire. I'm still up in the air on how far I want to lift it, I was curious on everyone's thoughts on that as well, and I want to get the best mileage/power I can. I don't have a tach, and had read that it might be hard to add one to my specific truck because of the ECM? I haven't found the factory rpm @65 with a 700r4 and a 29" tall tire, just charts based on I'm assuming a non OD trans. Any help is greatly appreciated!
