M122 blown 5.3 in my 99 silveraydo
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10, 99 Silverado
I found this gem... ive been doing free-lance machining here and there and one of the places I was doing turning for has this company truck parked out back.
07 ... 4.3, 4L60e
Big single Throttle body, CABLE driven, has a DISTRIBUTOR, and its got E fans. Strange combo for 07, but i know the 4.3's remained pretty archaic for a while.
It cranked right up and idled. He said I can take it for a grand, im coming back in a couple weeks to get this, and thats where my blown 5.3 will go. In the work truck WITH the ladder rack.
Moderator
07 ... 4.3, 4L60e
Those later 2wd and V6 trucks were kind of interesting. I bet if you look under it, you'll find a torsion bar suspension too.
Vbb199
Salisbury NC
Vince
The work truck i was wanting fell thru. The guy had to give it to his dad so I found another single cab long bed.
1999 single cab, no trans or motor. The rest of the truck was there, title included for 800$
There just so happened to be a 6.0 and 4L80e from a 2004 2500HD with harness and pcm for 700$ on marketplace also and since I needed a 2wd 4L80e for my project.... hellz yea
Ive told both of my brothers I have a 4.8 and 6.0... either one of them can have them for their projects if they get their **** together and come up with one
Vbb199
Salisbury NC
Vince
Got my front clip laid up there so she looks respectable and began clearing out the interior. Also worked on the stary headliner. The kid nearly had it done so im finishing it and will showcase that.
Its like 1000s of fiber optic lines lol
Supporting Member Army
Don't put an HD2 kit in it, they are a waste of money and the bypass will just stick and blow it up. Just manual dual feed it and do a sonnex boost and line to lube PR valve. I also did the Transgo AFL ream and replacement valve and TCC lockup valve while I had it apart. I used a Transgo separator plate and then just drilled it for the firmness of the shift I wanted.
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Daang it, was so lovin' this thread then it stopped....You're a goer Vince, watching with interest...
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
All this talk about boost reminds me how sick I was of dealing with boost problems…
Here’s what happens when the intercooler pump gets shut off. These CP pistons were $799 a pair
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
And yet NO Silver bullet..............
bluex
Spartanburg SC
C15
Hey! I got one (or maybe several) of those compliments of boost too :bawl:
Carb'ed Vortec 350
Is that the top of the piston? If so, what the heck was rattling around in there?
bluex
Spartanburg SC
C15
Yes, I can only assume it was the part of the ring land that broke off it. I haven't torn it down yet but it smashed the plugs too.
jw23655
