- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
As @77 K20 has stated, cold days are not vortec-friendly. I have similar issues when it's cold out, but I am running the stock air cleaner, etc. The only thing I changed was the heads and the intake, and then later the cam to a muscle car grind cam that doesn't have any more lift than the stock vortecs can take, and that engine runs very strong. Although the heads and intake are technically GM, and I guess the cam is too because they ran it in factory engines, everything else is factory GM from 1981 that came on the truck. If you went that route (Your Plan C), you'd be out money for two cylinder heads, an intake manifold, and a cam, so maybe $1,000. A weekend to swap it in, and smiles on your face from there on out from the increased power generated and money saved, and not having to tune this, tweek that.
