Lowest drop coil springs for c20/c30?
Truck82
Alderton
Christopher
Hey everyone,
I’ve been looking around for drop coil springs for up front and was wondering if anyone knew what’s the lowest I can go with just a spring? (No drop spindles)
I’m even thinking about cutting a couple coils off the old spring because I can’t seem to find any 6” drop springs.
I’m wanting to do 6”
Thanks for any advice!
Chevy 88
Canada
f7t6
GMC
How low you try'n to go?
Hey everyone,
You need spindles and springs,the coils won't be long enough to stay in place,and the spring rate will be crazy as will the A arm Tie rod and ball joint angles,and with that much move on the lower control arm,finding shocks that will work won't be easy either.
Truck82
Alderton
Christopher
Like this. Says it’s a 6/8 drop.
Just an FYI, you'll NEVER get it aligned with 6" drop springs. I've probably got 2.5-3" of drop with my cut stock springs and can't get the camber in spec. That crewcab is my buddy's truck, I just asked him what the combo is.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Hey everyone,
If you cut coils for that much drop, you need to move the lower ball joints inward. Back in the early 80s, before drop spindles, on my 81 C10, I had a local shop make me a set of coils that gave a 4” drop. I cut out a square around my ball joint, removed 5/8” more behind the piece, then slide ball joint piece back in and welded it. (Depends on your welding skills) On top of the cross member, where the upper control arm bumper hit, I added a 2” spacer to limit downward movement to keep the springs in the pockets. I removed the frame extension brackets and mounted the sway bar bushings straight to the frame. When I had it aligned, all they had to adjust was toe in (I had gotten it close)
Took a torch to some flat bar and bent up saddles for a rear flip kit. Offset drilled the holes about 1-1/2” to move the rear back to center in wheel wells. Ground down the front of the saddle to get driveline angles right. Went thru the parts store catalog to get shocks that were shorter.
That truck still has the same setup, as I saw it still running a little over a year ago and looked at it. Talked to the current owner several hours after I told him what and where a buddy stamped something into the frame. When I stated what was there, he realized I had built the truck.
Sad thing was, when I got rid of the truck, it was running a stout bbc, but currently has a small block.
Again, it all depends on your fabrication skills, as it can be done, and made to work. Back then, we built them, not bought them. You couldn’t just go buy parts and change them as they did not exist until a few years later when the craze really caught on.
Sorry for the ramble, and keep us updated on the project
I'm from the school of built not bought myself. It's amazing what you can do,when you have to. It's also incredible the amount of affordable cool parts available now that we used to have to make ourselves.Because even if it was a production piece it just wasn't affordable . Guys(me) homemade strokers,offset ground cranks etc. Narrowing your rearends. Now a stroker kit is everywhere for almost no more than doing a stock rebuild,and narrowed rearends bought ready to bolt in.
vr1967
Mississippi
Virgil
k1500
6.2L turbo
I'm from the school of built nit bought myself. It's amazing what you can do,when you have to. It's also incredible the amount of affordable cool parts available now that we used to have to make ourselves.Because evennit was a production piece it just wasn't affordable . Guys(me) homemade strokers,offset ground cranks etc. Narrowing your rearends. Now a stroker kit is everywhere for almost no more than doing a stock rebuild,and narrowed rearends bought ready to bolt in.
I know, back when we were turning 400 mains down and building short rod 383s, then turning around and adding main bearing spacers to 400 blocks to put the 350 crank in for a 377, etc etc.
Trial and error, digging thru the parts yards etc looking for swap parts, ideas, etc.
Yep been there,and offset grinding large journal cranks for different rods to gain stroke,running oldsmobile rods because 6 inch rods were way too expensive for the average guy building a hot rod.
Gearheadsqce
Davisburg, Michigan
C20 Crew Cab
I'm a retired Autoshop Teacher. Been through his with my own stuff and student vehicles many times since 1970. The best way to get maximum drops is to do a combination of things, spindles, springs and modified control arms. If you try to use only one method,you will wind up with terrible geometry. The truck will be hard or impossible to align and everything will hit everything else.
Read this thread
C20 suburban lowering issues
TotallyHucked has it right. Use Heavy Duty C30 springs and trim the coils as the final step. Leave it about 1/2" high and it will settle in to perfect! If you use soft springs, you will have to leave it 2" high and adjust after the springs settle. Another alignment, maybe two!
Truck82
Alderton
Christopher
I gotta ask, why not spindles? Keeps everything in alignment and ride quality.
I want the camber look. My neighbor has a ‘75 Ford that’s got the look I want but I know it’s easier to swap that springs on it because it’s an I-beam truck.
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
WTH is a "camber" look?
Johns C10 Hubcap
