license plate light
Nick.koehler6
IL
Nick
350 5.7L
How would I go about wiring a license plate light?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Do you mean where to wire it in or how to actually wire it in?
Nick.koehler6
IL
Nick
350 5.7L
How, what wire would I splice into? Could I run my own wire possibly?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
You can run your own wire but you have to wire it in the correct spot for it to come on with your light switch. Or you can splice into the tail lights and sauder them together, you just have to make sure you don't splice the power wire to the blinker wire otherwise it will flash.
In the rear lighting harness there is a brown wire that goes all over the place. It feeds the side markers, the parking lights and the license plate lamps:
You can splice into it anywhere - if you need to. But look around under there first. It is for certain that your truck originally had plate lighting and I'll bet it's still there. It may have been cut back at some point, but you should be able to find the stub.
Here is what the rear harness looks like - when it's layed out on the floor. This one is set up for dual plate lamps but yours should be similar:
WFO
Texas Panhandle
Chengny, I hate to bother you, but can you tell me what the black rubber thing, circled in the left picture, is? It comes apart, and looks to just be a connection. I've got power into it, but not out. Can it be omitted or replaced by a bullet conector?
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Chengy...can you post a pic of the rear tight light harness that decodes the different wire colors...I had had an issue with my drivers side brake light not working all of the time. I have been troubleshooting it for some time now. My turn signals work all the time...its just the drivers side brake light doesn't always get power.
Everything else electrical works as it should as far as the turn signal lights, running lights, hazzards and licensce plate light.
Thanks!!
crpntr78
Missouri
On my '86, that's the wire that goes to the license plate light.
alwaysbroken
