Leaf spring setup
Philipf9
Pa
Philip
I have a K10 but put on a gm14 bolt and Dana 60 in front. In doing that, the leafs that are on it are huge. Probably 1-ton but I can't find any info. The leafs have 8 in each one in the rear. The clamps is on 5th one down. I'm assuming the previous owner did add a leafs but I don't know. The clamps are shot and missing center bolt. I got new ones but I don't know if I should clamp on 5th one from too or 7th. Any advice?
Thank you in advance.
Craig 85
Nashville, TN
454/TH-400/NP205
Do you have 52" or 56" springs? My K15 had 6 leaves and were 52". I don't have photos of where the clamp was. My K30 has 9 leaves, plus the overload and are 56" long. Clamp is on the 6th spring.
Philipf9
Pa
Philip
I appreciate the info. Seems we both have 2-3 leafs unclamped. Your bottom ones are nice and tight. My bottom unclamped ones are fanned out and separated quite a bit.
chengny
X2 - except no overload:
Is there a bunch of rust buildup in the leaves? That can make them sort of fan out and look odd.
yevgenievich
Viktor
sad
very sad
less sad
or is it possible that it has 56" springs rearched to fit in place of 52's?
mattyb
