Largest tires on stock suspension
carpart67
Nova Scotia, Canada
Justin
K1500
I've picked up a 1986 k1500 High Seirra and it's in pretty close to original shape. That's rare for my area so I'm not sure if I want to lift it of leave it unaltered and put as big a tire as possible under it. I know 31s will fit no problem, but not sure after that.
Wondering if people could tell me what tire and wheel combos they have been able to run without rubbing or cutting? Pictures would be appreciated too, if you already have them around.
Thanks
towman
harrisburg pa
jay
v10
33 1250 15 will fit they fill the wheel houses up nice, will rub slightly when at a hard flex while turning sharp
Driver4r
Nebraska
Trevor
k10,c20
My 76 k10 has 32's on it.
Swims350
Logan WV
none
we had no rubbing with 33's
Driver4r
Nebraska
Trevor
k10,c20
32's have never rubbed and ive flexxed it pretty good befor. Ive heard 33's will clear, but wont allow much flex, cause then they start rubbing.
77 K20
Montana
K20 5" lift
HT383 fuel injected
A lot of it depends on what wheels you are going to run. On a stock rally wheel that was 8" wide I ran a 32x11.50 without rubbing. And it was a "large" 32 inch tire. From manufacturer to manufacturer there can be a difference in tire size.
Driver4r
Nebraska
Trevor
k10,c20
Old School BFG All Terrains.
83GMCK2500
Ellensburg, WA through Poulsbo, WA through Pullman
Devin
K2500
I don't have pics yet, but I test fit LT255/85R-16 tires on stock steelies on my K20 with old settled suspension. Turned lock to lock and it is close in the rear of the front fender but they will be fine. Those are like a 33.25" tall tire.
Stroked
Beloit, Kansas
Jared
I ran 33/12.50r15's on my old '86 K10 on the stock rally wheels for a while and they would rub if you were turning and going through a dip or over a curb. Lol. Not too bad, but enough that I took them off.
tman894
