Keep losing connection at battery
87ChevyR10
Kansas
NA
NA
NA
Is there anything I can do to keep the battery cables from wiggling loose? They are the side-mounted type. Doesn't seem to take much backing out of the mounting screw before I start losing juice.
Battery is an Interstate about 5 years old and holding good charge. Voltmeter is always around 14 volts with engine running.
Thanks!
350runner
tx
Ceasar
Sorry What kind of battery terminals do you have?
Sent from my LG-LS980 using Tapatalk
chengny
I remove the captured terminal bolt (the one with the 5/16" head that comes with the side mount style cable ends). Just force it out - or cut it and remove it from the terminal. Once it is out, replace it with a normal 3/8" -16 stainless steel bolt.
An 1 1/4" bolt works good. It is a little long, but you can dial it in with a washer stack. Place the washers on the back side of the terminal (away from the battery).
To address your specific question about the connections loosening up; be sure to include a lock washer somewhere in the stack. This will prevent the connection from loosening.
The washer stack also eliminates another problem inherent with side mount cable ends - it provides a good clamping point for jumper cables, a battery charger, etc. Grabbing on to the 5/16" bolt head with a pair of jumpers sucks.
Don't worry about the steel bolts ripping the threads out of the recessed battery terminals. Only the contact face is made of lead, the tapped hole in the terminal is actually a steel insert.
87ChevyR10
Kansas
NA
NA
NA
Cool! I'll try it out. Glad someone was able to read my first post.
Thanks!
sever
