K30 w/hydroboost clutch pedal solution
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
Be careful on your clutch selection. If you do the internal throw out bearing you'll need an matching pressure plate. I found that out the hard way...
can you expand on this please?
bluex
Spartanburg SC
C15
The internal slave uses a different pressure plate. The fingers are around 1/2" shorter than a clutch fork style one.
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
so '02 clutch,pressure and slave to match the trans? Im seeing folks using a GTO slave?
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
What trans are you using an what engine is it going behind?
02 internal slave nv4500
looking to put it behind a 6.2 diesel for now, until the kid an afford to put the 6.0 LS in
bluex
Spartanburg SC
C15
So use a flywheel that matches the engine, then everything else for an 2002 model. No need to use a gto slave, just use the truck one.
Jeremy89
