Junk yard parts to pick
mikeh4848
mineola texas
mike
89 gmc suburban
v1500
5.7l
hi all; anybody know why a 88-89 gmc v1500 sub is different than c k r series ? in question is the return and feed fuel lines (my return line ) sprung leak about middle of flex hose. nobody sells new part. I am using a line from my junk 92 1500 pick-up , its about 10in longer but, I made it work for now. mikeh
Moderator Administrator
Hey @Camar068, Just an FYI, LKQ DIY U pull it yards are again having 40% off. July 1st through July 4th.
highdesertrange
kalifornia
mike
k30
FYI, a note on the Gear Vendors the units are all the same no matter what it's on. the only difference is the adaptor and Gear Vendors will sell you the proper adaptor. highdesertranger
Right, so even if you find a Ford or Dodge RV with a Gear Vendor that you can snag for cheap, get it then you have to get the adapter for the proper transmission and you're set.
DarthKnight84
Colorado Springs
James
Silverado C10
I'm about to go grab some stuff at the pull n pay tomorrow and was looking for a list like this. Thanks!
Camar068
Air Force Supporting Member
10 yrs Air Force
regarding the Cherokee int. shaft, the first will take about 15 minutes (ratchet not power tools). After that it'll take about 5-10.
1. remove both bolts from each end of int. shaft under the hood
2. remove 4 bolts under dash lip holding column to dash (may have to take a cover off ....rip it off or be nice to the next guy).
3. take out 2-3 bolts holding column to floor
4. yank on the column, you should hear it hit the ground or drop out hitting something else
Save the bolts that go into the intermediate shaft.
Camar068
10 yrs Air Force
@HotRodPC , can you add "Fuel door hinge off 02-04 Jeep Cherokee for tail light fuel filler Mod.....Thx Mr. Clean" to the standard list.
Are you talking post #36. You did that just yesterday. I do believe I have the edit block set for 72 hours which is 3 days so you should be able to edit that one yourself. Give it a try so I know. If not, I want to go see what happened in the Admin control panel.
Or were you talking post #1??? I went ahead and added #7 and that Mod.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I just pull the steering box bolts it's only 3 and I don't have to lay on that nasty ass carpet and wait for some rabid mouse to attack me because it thinks I'm gonna take its 10 year old hairy French fry.
Camar068
10 yrs Air Force
post #1, Thanks HR. I'd like to keep the first post an updated list. That way you don't have to read the whole post to come up with a list.
10-4, Got'r Done !!!
Gurn
