Intermittent Random Missfire
GOBR
Memphis
You can also hear the missfire while cruisin if you have good bass on your speakers.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Hmmm...ya know, the Earl pump is driven by the distributor. But unless it goes to 0, I wouldnt worry too much.
Do check the distributor though.
Fill the crank case with propane to check for leaks under the manifold...you need to plug the dipstick tube, the breather hole, and pipe the propane in through the pcv hole in the valve cover, and listen for a change in idle.
:wtf:
GOBR
Memphis
Yeah I never heard of propane in the crankcase....... I have access to a smoke machine so Im good on that.
Jims86
Patterson,Ca
5.7 TBI
Smoke machine wont reveal any leaks on the lower part of the intake manifold gaskets.
John,
The crank case area is open to the lifter valley under the intake manifold via oil drain holes. If there is an intake gasket leak, the propane vapor will be sucked into the leak, and either speed up or smooth the engine out.
GOBR
Memphis
John,
Ahhhhh I see. So it would be like performing a leak down test without the leakdown equipment?
Jims86
Patterson,Ca
5.7 TBI
No, its more like sending a tiny robot under your manifold just to shoot some carb cleaner at the bottom part of the intake gaskets to see if they are leaking, just like you do on top. all with the engine running.
John,
I know, it just sounds like making a bomb to me that's all. What if that gets ignited somehow?
Jims86
Patterson,Ca
5.7 TBI
Then the ports on the valve covers would look like the back of an F-18 getting ready to shoot off a Carrier deck. Not gonna happen, no spark under Yonder.
Guardian
Jeff
c 10
Jim you have a way with words. You crack me up.
GOBR
Memphis
Got the oil problem fixed. Added a qt and its fine now. Guess Ill start usin 6 qts instead of 5. Still workin on the missfire. Broke till tomorrow and in between startin jobs soooooo. Heres a vid of the oil pressure and the temp it runs at. Nevermind the talkin some guy stopped next to me and wanted to know who does my body work.
Jims86
Patterson,Ca
5.7 TBI
Have you popped open your distributor yet, and looked at the advance weights, and the magnetic pickup?
GOBR
Memphis
No Im readin up on the advance and everything. The idle in the vid is not the missfire. I wouldnt be drivin if it was that bad lol. The distributor didnt have any play in it tho it was tight.
Jims86
Patterson,Ca
5.7 TBI
You must have a slammin ass cam in that thing!
Chype1
