interior light
sierra83
atlanta
decarlo
my interior light went out and i dont know if its the fuse or my wires and i dont know which fuse is which in my truck
J Knight
Baytown TX
82 Chevy
350ci
You can check all the fuses with a test light, or pull them out one at a time, interior light fuse should be a 10amp IIRC.
79K10
Sacramento,ca
Ryan
350/th350
maybe this is a dumb ?, but you checked the bulb already?
8T6K5
AZ
L98 350 TPI
There's the main dome light and then the lamp under the center of the dash. If the bulbs are good, and neither lamp works when either door is opened or the headlamp switch is rotated, it's probably just a bad fuse or maybe a broken wire.
It changed from year to year and different models, but the dome lamp often shares the same fuse with the horn, cig lighter, and radio memory.
79K10
Sacramento,ca
Ryan
350/th350
well i dont have a radio, horn,cig lighter or dome/dash light so im no help. lol
sierra83
atlanta
decarlo
thanks for the help every one
Dons79C10
