Inside the steering column, what is the steering "rack?"
Gpaw44
Alex
When I try to start my 86 GMC I turn the key till it bottoms out and it may of may not start. If it doesn't start I do it once again. Most of the time it will start the 2nd time. I have replaced the key switch and the ignition switch and have adjusted the ignition switch several times. Is the " rack" going bad and causinng this? Is it time to rebuild the column? Thanks in advance.
It is the steering "rack" and it's on the end of the physical ignition switch.
- The column switch has a small gear on the end of it and it fits into a toothed area on the rack.
- When you turn the key it moves the gear and the pot metal rack.
- The other end of the rack then moves a rod up and down the column.
- Near the end of the column you have a sliding electrical switch that is pulled and pushed by the rod.
So simple, what could go wrong?
This is probably the right one for your truck, but verify before purchase. https://www.ebay.com/itm/335375771674
When I researched this years ago I found that some switches and racks had a different number of teeth, and they have to match.
Hilllbilly
PNW
Elon
k20, c10
Hilllbilly
PNW
Elon
k20, c10
Its kind of a Pain in the Arse to replace. But not that bad.
Pull you steering wheel and just start taking apart till you get to it. Careful you might have one or two bearings fall out, so put a large plastic dish tub on you floor board to catch balls. Put some fresh lithium grease in the bearing race to hold the balls in place, and they wont fall out if you are careful. I had a couple balls fall out, but I caught them and put them back held in place with fresh grease. That was the only real PITA.
under
Gpaw44
Alex
Wow, You guys are great! Thanks for such great detailed responses!
When you disassemble the column you will find some internal bolts ( don’t recall exactly which ones) that have loosened up because folks use the steering wheel as a handhold to get in the truck. Highly recommend using lock tight on those bolts when you reassemble. Very common fix for a GM column.
This should help you was trying to find a pic of a broken rack to explain some things,but couldn't. I did find this for you. https://www.steeringcolumnservices....tiac/GM-Rack-Gear-Replacment-Instructions.php
What I wanted to explain was if the rack is cracked on one leg it will open the crack when you go to crank position due to spring pressure in the switch. If the rack is cracked you may buy some time by using your column only for on and off and using a push button switch to engage the starter. We'll I guess I forgot to hit the post reply button a couple of days ago. Sorry
Steelbuddha
Firefighter
Central North Carolina
Jonathan
K20 (dump bed)
That rotten little contraption can shut down the whole deal. It can also *appear* to be working properly when it is not. If the sector gear doesn't push the rack down far enough, it won't activate the ignition switch and you get no starter.
Since you have to disassemble the steering column completely to replace the rack and sector gear, it's not stupid to replace the turn signal switch and the wiper/high beam switch. It's a minor expense and can prevent major future headaches. Forty-year-old plastic mechanical gizmos do not improve with age. I suggest doing the whole thing once -- then you can forget about it.
jw23655
