Inline 6 devac
justhorns
Denver
Lee
Not sure. Which is the EFE.
EFE is the exhaust heat riser.
jrios104
new jersey
jonny
Started right up after priming the carb. OK, so I cheated by rebuilding the carb, setting valves, retiming the engine, but, with only a vacuum advance hooked up, and the stock air cleaner. Nothing going to any of the 4 Ported vacuum switches and all the junk removed from the valve cover. Engine runs better than fine (the other mods I did probably). Here is a picture of the back of the carb. Of the 4 ports I only have 2 hooked up, The advance and the secondary vacuum break. The other two for now are disconnected. and plugged. I'm gonna get the charcoal canister working properly, and the manifold preheat (what's gm call it?). Will upload diagram soon. Probably write this up in its own thread, someday.
What did you end up setting the timing to degree wise?
justhorns
Denver
Lee
To get it through emissions, it went to stock, on the label. I think it was 10 btdc. I'm about to add 15 more.
justhorns
Denver
Lee
Here is a few pictures as it sits now. The air injectors will be removed also. Performance wise, only timing makes a difference.
jw23655
