In-op speedo advice
78C10BigTen
pennsylvannia
C10 BIG TEN
So my speedo used to work then suddenly quit, i put a new lower cable on and noting. Changed the driven gear to no avail. Today while doin other work i pulled the cable off the trans and put it in my cordless drill and spun it, no speedo. I then unhooked the upper cable from the cruise transducer and spun that with the drill, not even a peep outta the speedo. Hit me with some advice here.... is my drill too ****** to make the speedo read or is my actual speedo gauge shot somehow?
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
You can spin the cable with your fingers fast enough to make the speedometer read, so i doubt it is your drill. Probably not the speedometer itself . check to see if the upper cable is in the back of the speedometer it pops in and i just held in place with a spring clip. you can reach up and feel it from under the dash. if not remove and check the upper cable.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Do you have one of those reducer boxes that goes on a t case?
Vbb199
Salisbury NC
Vince
I
No. 2wd i have one for sale though lol:p
Was thinking you could turn it backwards and try the opposite end with the drill.
But I think he's right, it should respond spinning it with your fingers
And after thinking on it, that wouldn't work anyways
78C10BigTen
pennsylvannia
C10 BIG TEN
Im really trying to fix my speedo. Its been in op for at least 3 years. Kinda hard to guess mileage every year for registration. Not that i wanta know how fast im goin i just wanta know my real mileage
Vbb199
Salisbury NC
Vince
Well, the obvious is, is it engaging into the back of the speedo? Is the socket in the speedo stripped out where the square isn't damaged.
idahovette
Weiser Idaho
Perry
K20-K10
Remember you need to have your drill in reverse to make the speedo run clockwise??
I would pull cluster, visually verify the cable spins on the cluster end while using drill. Its not a lot of bolts to pull.
Reread post 8 - drill must be in reverse!
Joe Smo
Toronto
Joe
If you have a smartphone use a speedo app called 'Speedometer'. It helped me when I removed my dash.
78C10BigTen
pennsylvannia
C10 BIG TEN
Ive goofed with this think for like 4 years. In the begining it used to just jump and hop then it quit and i never cared but every year when i gotta exagerate the mileage on my reggy and cant remember what i told them last year its gettin annoying. She hasnt gotten many miles in 40 years lol
Just checking! Not your first speedometer rodeo!!
Ls85c10man
