- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Man, talk about a roller coaster of a thread.
Thats the way it should have been. That line splittin has caused the purchase of new trucks.
Yep, and it's not really an E85 or Ethanol friendly part either.
Ya make a station for nothing but GM square body's lol
Well today is the day I work on my brown K5 hopefully I'll be able to post any and all results I will be fixing the iac idle and then testing fuel pressure because I can't hear the pump turn on like the other trucks fuel pump did
Yes to smog pump yes to the 88 distributor and no I'm using the computer from the 87....I also found out why Big Red stopped running on me the rubber line in the tank burst.
I knew we would find one! They have been found with small leaks in them as well, that drop fuel pressure to carb levels, and cause the running problems you are having.I'm keeping all the smog stuff.....I still have to look at the brown trucks gas tank still and make sure I don'thave that issue with the fuel line. I was happy to see that the red truck blew the house out because I was worried something else went bad and is causing all my issies
