Im stumpped
Man, talk about a roller coaster of a thread. :popcorn:
Thats the way it should have been. That line splittin has caused the purchase of new trucks.
Yep, and it's not really an E85 or Ethanol friendly part either.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
It isnt if is all you have ran in it. I remember all my Harley buddies coming to me when I was 17 to go through and re seal their carburetors when we had that big gas change back in the 90's. Go from running the real ****, to the new mix, and problems start to show themselves.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I'll hopefully have the problem fixed by the end of this weekend thanks to Jim and his plehthera of knowledge. I say he should me a moderator on here lmfao
He should be a radio talk show host.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ya make a station for nothing but GM square body's lol
Jims86
Patterson,Ca
5.7 TBI
I dunnomaboutball that, but this Forum has been growing like wildfire....I hope GM takes notice.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Ya no kidding people like Jim is the reason things like this spread
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Well today is the day I work on my brown K5 hopefully I'll be able to post any and all results I will be fixing the iac idle and then testing fuel pressure because I can't hear the pump turn on like the other trucks fuel pump did
Jims86
Patterson,Ca
5.7 TBI
Just one thing, you are using the 88 engine along with the 88 distributor, and are you still using the 88 computer?
Is there a smog pump?
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
Yes to smog pump yes to the 88 distributor and no I'm using the computer from the 87....I also found out why Big Red stopped running on me the rubber line in the tank burst.
Jims86
Patterson,Ca
5.7 TBI
:lol: I knew we would find one! They have been found with small leaks in them as well, that drop fuel pressure to carb levels, and cause the running problems you are having.
Go ahead and run the 88 computer, just incase there is a difference in the Ingnition modules...has to do with spark latency settings, there are 2 different modules available.
Dont throw away any spare smog stuff you may have in the pile.
Paulscrawler78
Ahwahnee CA 93601
K5 blazer
5.7L
I'm keeping all the smog stuff.....I still have to look at the brown trucks gas tank still and make sure I don'thave that issue with the fuel line. I was happy to see that the red truck blew the house out because I was worried something else went bad and is causing all my issies
Jims86
Patterson,Ca
5.7 TBI
BTW, you gave me an Email instead of a facebook addy. put Jim Leary in the search, and send me an add. My girls are my profile pic....a brunette and a little blondie.
KAR1130
