I might be in trouble
87scotty
Central il
Andrew
V20
5.7 for now
Yes it needs torn down for sure
chengny
found aluminum shavings about 4 1/2 inches long that are curved
Any chance of posting a few images of what you found. I've never seen - or heard of - big pieces of metallic debris in the pan of an engine that hasn't suffered a catastrophic failure (i.e. has not spun bearings, thrown a rod, etc.) and was still able to run.
Sorry man, we all sympathize.
1low4x4
Nick
I have. 4 cylinder Isuzu engine lost the thrust washers and allowed the crank to move back and forth wearing the ends down. Ran like a champ with 300x miles
78C30
NY
Jamison
c30
There was about 6 or 7 of these in the pan
78C30
NY
Jamison
c30
Talked to an engine shop and they said it is most likely a spun cam bearing as they are jacketed in aluminum
Carb'ed Vortec 350
That does not look good. Hope your engine is still rebuildable.
1low4x4
Nick
Ok, they say a spun cam bearing but how is the engine running? I know gauge indicates low oil pressure but its worth it to me to change out the oil pump and see what it does. I mean unless its audibly knocking like hell. New oil pump could make it last another 100,000 miles who knows
1low4x4
Nick
only reason I say that is because I've pulled stuff out of old pans in engines like that before, and nothing was ever wrong as far as I know, the engines were fine and I continued driving them
78C30
NY
Jamison
c30
I sure hope so! Haha I'm putting the new pump in and I have a mechanical oil gauge I'm going to hook up I also have a compression tester that I'm going to check them out just for the hell of it but I'm hoping for the best but preparing for the worst
78C30
NY
Jamison
c30
well im F@#$ed, changed pump didnt change oil pressure and had to drive home. on my way something let loose and now it sounds as if a pistion is slamming into the valves and it has zero oil pressure now and smokes so if anyone has a used running 454 for sale that would be greatly appericiated
78C30
NY
Jamison
c30
or a bigger motor than that such as a cadillac motor as long as its gm and 454 or bigger
1low4x4
Nick
Damn! Sorry dude it was worth a shot. You may have to settle for a small block in the meantime of finding a big block...I don't know about up there but down here they are not as easy to find in running condition
78C30
NY
Jamison
c30
I have the opportunity to rebuild the motor as my friend runs an engine shop should I try a rebuild or go with a different motor? What are the pros and cons of each?
Georgeb
Wisconsin
George
K10 Burb Z71
You can't make that decision without first taking it apart and assessing the damage.
aaron06
