I have no spark on 87 GMC V2500
dwittinger16
calgary, alberta
Dylan
v2500
Hey everyone I’m new to the forums I have an issue with my 87 GMC V2500 350 TBI I’m not getting spark but I have fuel and I’ve replaced well literally everything if someone can help a guy out much appreciated here’s a list of everything I’ve replaced
Distributor
Map sensor
ICM
Knock sensor
Throttle position
Rebuilt the tbi
Fuel pumps
Spark plugs
Wires
Oil pressure
The coil
And I’m getting power to the coil
gmbellew
Kansas city
glen
suburban 1500
make sure the EGR valve isn't stuck open. disconnect the vac hose from the EGR and plug it. then try to start the engine. if it starts, the EGR valve is bad.
are any codes stored? the coolant temp sensor could be bad...
if nothing else, walk through chart A-3 of the drivability and emissions manual...I am guessing you have a 4l80E as it is a 2500
dwittinger16
calgary, alberta
Dylan
v2500
I deleted the egr and I haven’t put a new temp sensor in yet I’ll try tomorrow but that wouldn’t affect no spark would it ?
gmbellew
Kansas city
glen
suburban 1500
read through the trouble shooting procedure I posted. coolant temp sensor is part of the step 1 check. I'd also double check all the plug wires to make sure they are on in the right order on the distributor.
if you deleted the EGR, but didn't update the computer, you will get the EGR code thrown on the highway when the system does a self test. it will clear when you restart the truck, but it will always do it.
4L80 didn't exist until 1991....
gmbellew
Kansas city
glen
suburban 1500
gotcha. I have a 1990 V1500 and just use the 1991 manual because I don't believe there were any changes for my rig. he may need to pull up his correct year manual out of the reference library and get the correct chart.
dwittinger16
calgary, alberta
Dylan
v2500
I have a th350 transmission in it will upgrade to the 700r4 but I will try the temp sensor
dwittinger16
calgary, alberta
Dylan
v2500
Zero codes are stored as well I’m just getting zero spark
No codes is odd with zero spark. How did you test for spark? I suggest getting the correct 87 manual out and follow the troubleshooting flowchart. I know its a pain, but this is fully electronically controlled spark, so you could have everything connected properly and right and have it still not run if the ECM is bad.
https://www.gmsquarebody.com/threads/1973-1991-service-manuals.14499/
Go down and download the "1987 light duty truck fuel and emissions including drivability" manual
There will be a flowchart for no spark or no start like the ones gmbellew screenshotted for you. They will walk you through verifying all of the circuits and systems that could be causing your issue. Just throwing parts at it is the absolute worst thing you can do.
M37M35
