Hydraboost question
TubeTruck
East TN
Denis
Suburban K10
LQ9
I want to put hydraboost in my '78 'burb and have an opportunity to get one off a 1979 K30. Problem is it has manual steering and I'm not sure if the boosters were the same as the ones with power steering. Does anyone know if it has the pressure out port for the steering box? Or should I continue to look for one out of a power steering truck?
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Did you count the number of ports on the hydroboost unit?
TubeTruck
East TN
Denis
Suburban K10
LQ9
No, it's an hour away from me and I haven't contacted the seller yet. Was just curious if anyone ran into a hydraboost setup with manual steering or if anyone knows if they are the same with a plugged pressure port.
TubeTruck
East TN
Denis
Suburban K10
LQ9
Haha, I'm an idiot. Disregard this. The ad said it had a manual steering column. It's a stick, not manual steering LOL
Nonstop
Ca
Nick
K2500
How much is he asking? I finally caved and bought a parts store one because of the lifetime warranty. Might want to price one and compare.
TubeTruck
East TN
Denis
Suburban K10
LQ9
I'm actually hoping to get 2 setups. This guy has a '79 and is asking $75 for everything, booster, master, lines, and pump. But he's overpriced, he also wants $250 for the hood, lol.
Also seeing if someone down in St. Louis will ship me the one they are selling. It's off an '83 and has everything and he wants $25. I offered $40+ shipping for his troubles. He's checking into shipping prices.
Snoots
Roger
Jimmy Sierra
You really had me going at, 'a 'Burb with manual (no power) steering?'
Dutch Rutter
Independence, Or
Joshua
I believe you will also want to pickup the pedal assembly from a hydro boost truck. Iirc they are different.
I could also be imagining things.
TubeTruck
East TN
Denis
Suburban K10
LQ9
I've heard the mounting pins on the pedal were different, but I've installed them on vac boost trucks before without swapping the pedals and they've always worked fine. If I run into a problem I'll just drill a hole and weld in a bolt, lol.
Dutch Rutter
Independence, Or
Joshua
Good deal! Gives me hope for doing a hydro swap after I swap to a 5 speed. :waytogo:
Snoots
Roger
Jimmy Sierra
The pin IS in a different location on a hydroboost.
TubeTruck
East TN
Denis
Suburban K10
LQ9
It may be but I've never had any problems installing a hydraboost on a vacuum pedal.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
I'm actually hoping to get 2 setups. This guy has a '79 and is asking $75 for everything, booster, master, lines, and pump. But he's overpriced...
Not overpriced at all. I bought a used HB unit off craigslist for $20. It leaked. Thought it was a waste of twenty bucks until I went to buy one at the auto parts store and found out there was a $60 core charge. So the craigslist deal ended up saving me $40.
SMC2224
