How Will My Square Body Look With XX Lift and XX Tires?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
for a tire that wide on a 8" rim it is very easy to over inflate them and then the tire just rides on the center of the tread.
You can take some chalk and draw a line across the tread and then drive straight for 50'
or so on pavement then get out and look to see how the chalk is wearing off. Then adjust the tire pressure accordingly.
The shop filled my tires to 70 psi after mounting them. It would rub off in the center and not at all at the edges. Think I'm down to 35 psi now.
Oh yeah I never fill them more than like 35 or 40 on this truck. Last I checked I was at about 30 though and now temps are dropping I wouldn't be surprised if there was only 20 or 25psi in there. They're definitely not ballooning out, if anything I'm only riding on the edges of the tread.
rumblebox
Victoria, TX
Carlton
4" lift on 32x11.50r15. stock rallies.
Bosshog454
Arkansas
Branson
Suburban v2500
1991 chevorlet suburban v2500 4x4
4 inch rough country lift
35x12.50r17 toyo open country MT
17x9 mickey thompson classics
3 in blocks in back , 2 in. Leaf in front on 33's
not sure how those donut marks got there ..foot musta slipped off the clutch ..
Hate when the foot slips off the clutch. Especially at full throttle. :happy175: Kinda how I did back in the day with the Muncie M22 4 speed. Rev it up to about 3000 rpm when the hands dropped, just side step the clutch and nail it to the floor.
idahovette
Weiser Idaho
Perry
K20-K10
Had a 56 Chevy 2dr wagon, 327 ,11 to 1, tunnel ram, 2 600 holleys, Muncie, 5.13 gears with 9.00x15 wrinkle walls at about 10-12 lbs air. Used to set it at 5,000 and sidestep it on last yellow. Then you had to catch up to everything and start grabbing gears. Good ole days!!!
Bigred3plus3
Washington
Kyle
V3500
Not exactly sure what the lift is since I just bought it but was told 12 inch. Not sure its 12 but those are 33s lol will be putting my 37s on it once the LS swap is done.
78C10BigTen
pennsylvannia
C10 BIG TEN
Only looks lifted in the front lol
nvrenuf
Mobile, Al.
Looks more like 6"~8" to me.
Measure the distance between the bottom of the frame rail and the top of the axle tube on the front, stock is +/- 8.5". (ex; measured at 14.5" ----- 14.5 - 8.5 = 6, result is 6" lift)
TubeTruck
East TN
Denis
Suburban K10
LQ9
1978 Suburban K10. Stock suspension, worn out a bit actually. 33x10.5x15 DC Extreme Country tires. Stock 15x8 rims. No Trimming.
71RAT
Deerfield NH
Kirk
K20 Scottsdale
Loving the slots!!
Unfortunately they're 16.5s and will be going away when the BFGs wear out. You can't give then away around here, probably scrap them when aluminum price is up.
