How to fix loose gm steering column
Interesting. See how your's has that space between on those splines? Mine isn't like that, it's consistently spaced all the way around. Wonder if I got a reject. :roflbow:
Is yours non-tilt? I know the plates are different between the two.
SlickGTP
Houston, TX
That's a good question... I'll look at my non-tilt column when I make the switch to the tilt I'm working on now. Might be awhile though... In the meantime though I'll take pics of the tilt I'm working on now and get those up. It's an earlier model than what 89s was working on, so there are slight differences.
hinkv10
ct
craig
v10
At this point it is very easy to remove the shifter spring. I think mine was the wrong one, for a non tilt column as it was too short. It didn't appear to have broken. I tried to remove it after taking the shift lever off but it was jammed in there and I couldn't fish it out. By tearing the column down I was able to use pliers to pop it out and install the new one. It was very easy at this point because you could line up the spring with the shift lever and pop the pin back in. My guess is that it would be a serious pita to do it without tearing it apart.
You have to re-thread the tilt lever back in place, and tilt and pull assembly down all the way to disengage the teeth, then she opens up like a prom date in heat.... :waytogo:
:wtf:
image host
Damn dude, thanks for pointing that out, I never noticed the spring until you said that and I looked at that pic a little harder. :)
83swb
CT
Hunter
83'
350/th350
The tilt column in my new cab is VERY loose. It not only moves side to side, but it doesn't fully lock when adjusted so it has alot of play up and down too. The truck was in a front end collision so could my column actually be broken or is this also a symptom of these loose bolts in the column?
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
Loose bolts.
83swb
CT
Hunter
83'
350/th350
Thanks :worship:
Yep, somewhat of a common problem. I need to do this to my 85 K1500 too. I've put it off waiting to get out to my dads, where I have a 4 spoke wheel I intend to install on reassembly. I'd also recommend using LocTite Blue Hand Tool locktight to keep this from happening again.
RetroC10Sport
Jay
pontiac aztek
Spring installed with set screw.
Full lock, key in accy.
Key in wheel unlock.
Unlocked, key in START.
RetroC10Sport
Jay
pontiac aztek
And of the 3 screws holding the switch to the column, the upper right one is special to that spot, a pan head, and the other two are the same, keep reference...
One of the 3 Phillips head screws holding the turn signal switch assembly to the column is connected to a small piece that connects to the turn signal lever, remove and reference it's location....
upload pictures
adult image hosting
Someone put that on wrong, the pan head goes on the "directional switch arm" so someone had it apart before and didn't put it together right.
That must have been me, I had it apart before, LMAO! :roflbow:
I'll check it today. I still have to install the cancel springs. Just too damn cold and windy yesterday to be outside. Thanks for the heads up.
Posted from mobile...
LedZeppelinXV
Tennessee
Shane
C15, K25, C65
305 LE9, 350 Goodwrench, 366
what about the issue of the key getting hard to turn in the start position? in my shitbox 85 the switch feels normal 95% of of the turn and then just as it is about to crank the engine, it gets a lot of resistance. i think the exact same thing started to happen to my uncle's 77 before i destroyed the switch with channel locks; i put a push button in that one.
Stickman
