How many freeze plugs on a 350 SBC?
projo198
Lawson MO
James
Hey all. I am wanting to get some parts on the way home and NOT go anywhere tomorrow while I work on this motor.
Everywhere I see online says there are 4 freeze plugs total; 2 on each side.
HOWEVER I know for a fact there are 2 on the front of the motor to either side of the water pump.
Anyone know the real answer and what size they are supposed to be? I believe this is a mid-80s SBC.
Chevy 88
Canada
f7t6
GMC
Looks like 8, and a total of 12, according to this link:
legopnuematic
Licensed Junk Dealer
MO
Spencer
For a 350, two on each side, two on the front, two in the rear. Then there are galley plugs for the oil passages that feed the lifter bores.
Get brass ones. You should be able to get a kit of them, with all of them.
Not relevant here, but a 400sbc has three on each side.
fast 99
Spokane, Washington
Will add most 2 bolt mains were 2 soft plugs per side, 4 bolt mains were 3. Back in my racing days we cheated rules by using a 2 bolt block [with aftermarket splayed caps] claiming it was a 350 which it wasn't. Was a 400 block with 350 crank.
wonone
