Terlingueno
Fictional Western Sage
- Dec 29, 2020
- Far West Texas
- Skeeter
- K20 Suburban
- 350/SM465
Now that I have the time to really take the deepest of deep dives into my '85 K20 Suburban that I purchased in '94, I have some questions, this one involves spark plugs. The OEM specs per the owners manual states R44T. The original engine was a "Code M" heavy duty emissions, which according to the owners manual required 89 octane leaded fuel. When leaded finally disappeared, I started using unleaded. Truck ran great, miles piled up, in 2007 at 325K, I had a GM 10067353 350 crate installed. Now we are approaching 450K miles. It is and has been my only vehicle since '94, and need it to last as long as I do.
The specs on the crate motor state 87 octane gas and R45TS plugs. Been using both since '07. Truck runs good, but different than the OEM engine.
From what I can find on the interwebs, the original engine had 8.3:1 compression. The advertised specs of the crate motor state 8.5:1.
I am wondering why the heat range difference between the old engine plugs and the crate's. Pretty sure I know why the extended tip plugs are called for. The Sub is heavy, appx 5700lbs. I think I can I use R44TS plugs? But do I need to? Maybe someone can splain this difference to me?
