How do I remove lock ring in column?
87ChevyR10
Kansas
NA
NA
NA
My key switch is falling apart. Latest was the chrome helper ringer fell off. I've got a new one I bought long ago, but can't seem to get passed the lock washer / ring that's behind the steering wheel. What's the trick?
Thanks
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
You need an inexpensive lock plate spring compressor.
87ChevyR10
Kansas
NA
NA
NA
My truck doesn't have the lock plate. Will that tool still work?
PO installed aftermarket steering wheel and didn't reinstall lock plate.
yevgenievich
Viktor
sad
very sad
less sad
Does it look like the picture retro posted?
87ChevyR10
Kansas
NA
NA
NA
I looked again and the plate is there. Bought the tool and got the tumbler swapped. The tire bolt hole is stripped out and found the turn signal mechanism is cracked where that arm screws in. Also, the steering lock is broke. The rod does not extend completely.
I guess the PO had the lock plate installed wrong. Steering wheel is now proper.
Thanks!
630erik1
