Homemade and modified tool thread
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
home made 4l60e / 700R4 spring compressors
Very nice. I do mine on the hydraulic press. That looks much easier haha
Modified bead breaker for my junk manual tire machine. So far real happy with the results.
Forgot to attach the pic. Sorry.
Fixed it.
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
homemade jig for drilling a Kalashnikov receiver and modified bolt cutter for the rivets.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Here's a couple.
Jig for the blade plow shanks.
Welding chuck, have plans for a redo.
couple odds and ends
Galane
Idaho
Gregg
Sierra 3500
No picture handy but I made a long reach tool for changing those curly fluorescent light bulbs. Cut two pieces of cardboard about 3x4" Cut halfway across the middle from one of the 3" sides then slide together in an X. Notch one side to fit over the end of a piece of PVC pipe. Cut the other side of the cardboard X to fit into and outside of the bulb coil, using a new bulb to check fit. Hotglue the cardboard onto the end of the pipe, also gluing at the X joint.
Stab it up onto the bulb and unscrew. Works to screw the new bulb in.
And for the ATF observing this post you definitely filed all appropriate Form 1's for that..... definitely
C10MixMaster
Kingman AZ
Ben
C10 BIG10
ZZ4 350
it actually did. I guess they considered it a 90% receiver and had to go through a FFL. However it was lost in a tragic boating accident.
squareframe
