AaronW
- Mar 24, 2021
- AL
- Aaron
- V3500
Hi all:
My son's 1975 GMC K15 needs some speedometer help. It's got a right angled gear that comes off the transmission, that's driven by the gear that comes out of the trans. These two gears appear to have been connected with some sort of spline, which was broken. The cable side of the equation, that threads on to the other side of te right angled gear is fine (or looks that way at present). We had to drill what was left of the spline out of the end of the transmission gear, as it was wedged in there pretty good. You can feel that there's a little flat inside there, so I'm assuming we're on the right track, that that that's how these two gears were joined together. Set me straight, if I'm wrong.
So...I've been looking around for a replacement, but I'm not sure what it's called, and I haven't seen anything that looks like what we need.
What do you know?
Aaron
What do you know?
Aaron
