Merlin3e9
- Jun 28, 2018
- Crestview Florida
- Jason
- R10
- 5.7L
Hi everyone,
Question for all my fellow Squarebody owners. I am about to pull the trigger on a complete set of Hella sealed beam conversion lamps for my 87 R10, but I am a bit confused on which to buy. My truck has quad headlights.
Just need some clarification on which part numbers to replace my high & low beam headlights.
According to Hella's website, the following are the part numbers suggested:
- 4"x6" Rectangular Conversion Headlamp Kit, High/Low Beam (ECE) 003177801
- 4"x6" Rectangular Conversion Headlamp Kit, High Beam (ECE) 003177821
From what I can find, the High/Low beam kit (801) comes with an H4 bulb and the High beam (821) kit comes with an H1 bulb. Are these the two kits I require for my 87 R10?
With an H4 bulb having a dual filament, is this correct for a single low beam light? Is an H1 correct for high beam?
Lastly, I know an upgraded harness is strongly suggested, but I'm confused on which one to buy. I know the LMC brand is okay, and does the job, but what other quality harnesses are out there that won't break the bank? Also, are upgraded harnesses out there for an H4 low beam and H1 high beam? Do I need one or two harnesses?
All I'm finding are H4 upgraded harnesses. Can't find any H1 harnesses. Will an H4 harness adapter plug into an H1 bulb? Below is one example of a quad light H4 harness I've found, but it's pricey...
- https://www.painlessperformance.com/wc/30814
I also know a fellow forum member, gmachinz makes high quality harnesses for lighting upgrades.
Any advice is greatly appreciated,
Thanks
Jason
Thanks
Jason
