Gun vault dash.
eskimomann209
Modesto
Marcus
So getting the templete to fit was almost the worst part. Once it fit great I cut the aluminum. As normal it didn't fit. Had to trim it more than I wanted because I couldn't get it to bend like I thought it would. But got it in and going to fill in the gap with 3m 5200. If I did it again and bought a sheet I would use thinner gauge. Drilling the holes for the vents was the most tedious part. Should have drilled from the top. It made rough on the outside. Also I scratched it up bad but I don't care about scratches. Rivited the Vin plate on too. I sprayed afew coats of clear coat on it maybe it won't rust any more.
It seems like you said you sprayed a clear coat over rust? That won’t do anything to stop it. It’ll rust from the inside still.
WomenandthePolice
E OR
Char
Cut the front piece,j have to cut a notch for steering column. Then hole saw gauges. I still don't have a plan for the door. I have a piece of angle aluminum I'm using to rivet the top to the bottom.
WomenandthePolice
E OR
Char
If the Vin plate does completely rust out I'll just make another.
eskimomann209
Modesto
Marcus
Omg it’s ba.... oh... hmmmm..... wait....
I like it. Carry on.
WomenandthePolice
E OR
Char
Got front cut out and temporary in. Had to pull the blower motor out. It quit this morning. Got a vdo brand one from Auto zone. It's huge air flow difference from the original.
Hope can get some holes cut out and some wiring figured out.
WomenandthePolice
E OR
Char
Does anyone know what wire goes to the check engine light?
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
eskimomann209
Modesto
Marcus
Dark brown with a white stripe? I think it’s in slot 16 on the cluster plug.
or it’s brown and white on 15 spot.
I wrote these down a while back for a plug swap around. But it’s been a while. I know it’s brown and white at 15 or 16.
eskimomann209
Modesto
Marcus
Sure they do
WomenandthePolice
E OR
Char
The spring on the tbi is not closing all the way. Going to pull it off and clean it up. I tried spraying it down with brakeclen but no change.
NateP350
