Grab handles on inside pillars
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
Thinking of bolting these in to the pillar to assist entry. Anyone else try this vs the big metal ones? Would it be possible to rivnut anchors into the pillar between the windshield and door frame or better along the roof closer to the windshield?
SquareRoot
The metal is fairly thin. When I made my handles, I welded a B_U_N_G" to the pillar so the attachment bolts had something to grab to. The other issue is the way the pillar faces inward and forward. That makes the face point towards the glass. So unless you have your windshield out, It's almost impossible to drill or screw a bolt in straight.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
I saw your post and was hoping for a "no weld" solution. Thanks.
That's not likely. Can't see how you'd complete this project without welding especially to add rigidity to the A pillar which was never built for this intent. You gotta add strength to that attachment point without a doubt.
SquareRoot
Also, its multi layers. Behind the initial metal there is another layer at an odd angle. You only have about 1/4 inch to play with. That's why the b_u_n_g idea allowed me to thread the hole and use a 3/8" bolt.
You could probably use a nutsert and a spacer but either way the glass is coming out.
SirRobyn0
@Ron Sebastian Take a look at SquareRoot's thread. There is his, build which is really the nicer one and my simplified version is later on in the thread. I won't not the grab handles in your picture personally. The pipe handle is the way to go.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I used those exact soft handles, right above my head on the roof and door line. Suburbans have some sandwiched body panels in that area.
I used 3/8 nutserts and it holds them perfect, I can't see any flex in the metal with all my weight. You just have to make sure you space the holes right, so there's some slack to get your hand in there but not so much it looks like a dumb floppy loop.
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Good info. Where did you get the handles from if I may ask?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
Amazon 25.99
Bartact TAOGHRPBG - Wrangler JK Rear Side Sound Bar Paracord Grab Handles (Pair) - Made in USA - Black/Graphite​
damon18
