Gauges Paint
GaK10
GA
Bo
Has anyone repainted indicator marks on their OEM gauges?
I cleaned mine recently and all was fine. Not sure if the heat has anything to do with it, but some white marks and orangish warning zones have disappeared. Does anyone know of a OEM color/paint match?
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I wonder if most of the faded ones are just needing buffed out lol. But probably not the white ones that have a bend to them. I know you can paint them too if careful
Bennyt
Surprise
Ben
I bought my paint and gauge faces from whitegauges.net. They have 4-5 different colors of paint and 30-40 different face colors.
fast 99
Spokane, Washington
try a hobby shop. I use paint below. other colors are available. would clear coat after color. Used it on a motorcycle tach that was obviously exposed to UV. It faded a bit.
Spray a puddle in the cap, use the torn end of a paper match as a brush.
ChuckN
Bellinham, WA
Chad
Saw a guy redo his on YouTube, he just used orange Testors model paint and a very fine tiny brush to do it. Looked pretty good.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Don't touch the gauge faces with anything. You will wipe off the paint. 100%
ChuckN
Bellinham, WA
Chad
This. I had to be very careful around mine- at this age I found by just accidentally touching the old gauge paint that it smudges like chalk.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I'd be afraid of compressed air even. Maybe from really far away or an air duster can lol
I learned that lesson the hard way as well.
GaK10
GA
Bo
I cleaned mine, everything was fine nothing came off. I reassembled it and put it back in the truck. After a few days, some markers were gone.
squaredeal91
Greg bush
1991 SB
I imagine it would depend on the level of oxidation. I carefully buffed the faceplate on my 62 scout successfully. But not so well with others. The white letters smear and rub off easy.
Raider L
Shreveport, LA
William
@PrairieDrifter,
That is true. I found out the hard way when I was trying to clean the face on my shift indicator. the letters smeared right off! It freaked me out. I had to get out the model airplane paint and a fine bruish and try to repaint the letters. The other thing you can do is go to a Hobby Lobby or similar place and look for the rub on transfer lettering sheets. If not then you may have to order a sheet off line. They are called "transfer sheets". Or if you have a better art store in your town they may have them. Also, drafting supplies stores may have them. Just clean the letters off altogether and spray paint the gauge face semi-gloss and do the face from scratch. Better yet do like do like Bennyt suggests. There are all kids of ways to restore these gauges. It just depends on how patient you are or how much trouble you want to go to.
curbstone mech
westminster md
allen
k20
Not sure if this was mentioned but when I pain ed my needles I cut a slit in some waxed paper and slid it under the needles. Luckily I only had to dust the guage faces
TDoc
Flagstaff, Arizona
Terrell
K10, K5
I just repainted the gauge needles and red markings using model paint on my 1979 K10. Turned out great. The paint levels out really well but you can tell it’s been painted. Still a big improvement over the faded look.
TDoc
Flagstaff, Arizona
Terrell
K10, K5
Next I’ll do my 86 k5 with the orange gauges. I can’t find an orange that is exactly the same. Testors orange fluorescent was close but I didn’t like the glowing orange look. Tangerine gloss is a bit lighter but should turn out ok since the rest of the gauge face has lightened up over the years.
squaredeal91
Greg bush
1991 SB
You can mix it. I mixed up some pink a couple years ago and painted a red hot wheel pink for my daughter.
Hard
