fuel pump
if it is normal why does it stay on when truck is running? i would of also thought it would picked up no fuel pressure?? and no egr lol does it not check these things?
Dude, I am going through the same hell myself trying to figure it out on mine, I think my computer is trashed. It's running lean, EGR solenoid control is jacked up, phukin engine light comes on after de-accel from highway speed and cruise kick off, and it refuses to put codes out to diagnose. I am very frustrated myself. :help:
Might have to swap a phukin 2bbl carb onto it. :lazer:
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
I can only tell you what code 12 means lol sorry man.
AMW
Adrian
R10 Silverado
this is agravating i sorta wish this engine was carberator aswell lol ALOT easier to deal with
As for your hood gaps, it looks like your entire front clip is shifted to one side. It could be that the radiator support bushings need loosened and the front clip shoved over, or the frame could be bent too.
AMW
Adrian
R10 Silverado
ouch hope the frame isnt bent if it was what does it take to fix that lol
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Couldnt see your video. either link. does it flash code 12 more than 3 times? each code stored, will flash 3 times before moving on to the next code, then will end with code 12 again.
computer has now way to know fuel pressure.
Sounds to me like somebody went through that truck and really ****** it up. Carbs are more of a guessing game, compaired to TBI and more advanced systems.
crazy4offroad
Curt
K-10
350/SM465/NP205
It flashed about 15 times lol code 12 over and over.
Jims86
Patterson,Ca
5.7 TBI
Needs to check his wiring.
Maybe the fuel pump circut was "improved" along with the external pump....LOL
AMW
Adrian
R10 Silverado
lol i know the guy befor me he did things i would call not proffesionall and now im trying to fix it , far as wiring goes i know with the external fuel pump they have it rigged up running at all times when key is on or truck is running so its tapped into somewhere but the gas tank pumps are un touched it looks they still have connectors and no cut marks
Jims86
Patterson,Ca
5.7 TBI
Oy....you have a project on your hands.
AMW
Adrian
R10 Silverado
ok i fount the wire it is blue wire with tape on it not sure what it is tapped into but here some pics
AMW
Adrian
R10 Silverado
so i took the blue wire out it was just taped with the ignition wire and stuck in the little ignition port but the ingition wire is fine wasnt cut or anything so still stumped on this service engine light i try unhook positive battery cable for 5 minutes turn key on still stays on unhooking battery shouldve reset am i right?
It will stay on with key on engine stopped. Once engine is running it should go out.
AMW
Adrian
R10 Silverado
so i got my new fuel pump on my right side tank not worried about the left atm the pump came with new wires and clamps gaskets etc... the little hose they sent with it tho about 3inches long didnt fit so i used the original one tested it make sure it didnt leak first, now gotta get hose for fuel selector valve to fuel filter was wondering tho how much gas do i need for the pump to pick it up to run? the minimum amount of gas i mean cause i got 2 2and half gas cans if i fill those up and put in gas tank would the pump pick it up to run? Also forgot i put new strainer on aswell got the Delco ep386 pump from amazon
Guardian
Jeff
c 10
That should be enough to pick up.
alwaysbroken
