Front frame bent?
Bighead72
chevy c10
Is the front frame bent?
1STLS1
West Phoenix AZ
MIchael
I would use a measuring tape and "X" it out. Measure front the front rivet on the passenger side crossmember to the center of the bumper bracket bolt hole on the drivers side rail, then repeat on the other way. If it's square , the measurements would match. I have a funny feeling they will not
Ontheboulder
colville,wa
greg
gmc sierra classic v2500
my guess is the passenger side has a definte bow in it
nvrenuf
Mobile, Al.
It looks bent to me. Any signs of a crease on the outer vertical wall of the rail?
Will a bumper easily bolt on? If not, you have your answer.
Bighead72
chevy c10
I’m going to try to bolt bumper on. Is it worth fooling with or junk it?
Looks like it's just the front horn, that'd be very easy for a bodyshop to straighten out. I'd get 'em to pull it and move on
nvrenuf
Mobile, Al.
If all of the damage is forward of that front crossmember I wouldn't be afraid of it after it was straightened. As stated, you need to spend some time checking the frame to see if it's square or not behind that crossmember.
SquareRoot
Let's just say....thank goodness it's not an arrow!
Bighead72
chevy c10
Should it be even width front to back?
1STLS1
West Phoenix AZ
MIchael
This
All of these trucks had something happen over the years, the next one you might find would be worse
nvrenuf
Mobile, Al.
No, the tail end of the frame is wider. Iirc, the frame tapers in at the area around body mounts under the front floor board.
Camar068
10 yrs Air Force
curious, after the crossmember is there such a thing as a center point to reference? Have been wondering if mine is out at all.
Do you know how to build a string box for doing alignment? I'd build a string box,center it using the wheel hubs as as locators as in 5in to lf hub 5in to rf hub 4in to lr hub 4in to rr hub, just example numbers. Then use 3 4 5 formula to make sure your frames square. If so then you can take measurements side to side to see where right front needs to move to. I'd probable move it myself.
  • Like
Reactions: WFO
How to make a string box. Similar to mine I used conduit just looked up a link for you,never thought pvc.
Okay this is more like mine sorry trying to find u stuff spur of the moment.
Look at the bottom link of post 14. You could add a center string under the truck but you'd have to make some short stands for the conduit
michaelmarine53
