1987 R10 Fuel Tank Shield
tmwork
DFW
Tim
I have an 87 R10 with dual 16 gallon tanks. I need a fuel tank shield for the driver side tank. Anyone know where I can find one? It's #8 in the diagram
84GMCSierra
Supporting Member Air Force
Central Arizona
C2500
Couple of questions: is it the plastic cover? Do you drive your truck daily? I ask as several of us have ditched them because they hold dirt and debris which can lead to rot and damage to the tank(s). I had the tank on my old 65 Chevy II Nova sprayed with bedliner. Protected it and unless you really looked, it wasn't noticeable.
Gander
Army
Dirty Bay, TX
Lawrence
You really don’t want to run those full covers. As someone else already pointed out, they’re a poor design. They trap water/mud/dirt and hold it right up against the bottom of your tank which ends up rusting your tank out.
Earlier year trucks ran a partial shield on the leading end of the tank. I found a set of those and put them on. Even with them it would be a good idea to drill some drain holes in them before installing them.
76Dump
