Help Installing Pre Bent Brake Lines 1980 GMC
Jake43
Virginia
Jake
Classic Tube CT1013-SS - Classic Tube Pre-Bent Brake Line Kits
I just bought this kit. Very happy with this product. My question is when installing do you run the front line behind the motor mount and frame? I assume you feed if from the rear toward the front and bend toward the P valve? Any tips would be helpful. Thanks in advance. New Member
Trucksareforwork
Spartanburg SC
Geoff
Yeah. That’s the way I did it. You have to flex the line quite a bit to make the corner.
Jake43
Virginia
Jake
Just about every video had no motor and no bed. Just the frame. That would have made it so easy. But not my luck. LOL Complete running truck. Ive been looking for patience but haven't found any yet. I guess it will be alcohol. If anyone one has a good link for this it would be much appreciated. Thanks again
Joestreml
