Front End Noise
Jwasnewski
Dawsonville, GA
Leroy
GMC SUBURBAN SLE
5.7L
I am about to go mad trying to find a front end noise. It sounds like a golf ball in a cardboard box when running over bumps or cracks in a road. Left side. Applying brakes doesn’t change anything. Steering changes no difference. Everything is new up front, bushings, ball joints, steering Box, intermediate shaft, the works. This started after I had a so called mechanic run new parts in the wiper system. Stalk, turn signal switch, board and motor. It acts like a loose shock but——they aren’t loose. Nothing appears to be loose anywhere else. . It’s running me nuts.
1989 GMC 4WD Suburban.
Did they leave a tool or old part(s) where the wiper transmission is?
dvdswan
Port Orchard, WA
Dave
Welcome to the site. Do you have center caps?
78C10BigTen
pennsylvannia
C10 BIG TEN
I was gunna suggest loose shock as my dads ol c10 used to have that issue and sound
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Rear only!
Very cool ride. Do you know what make, model, part number or any other number that step bar is?
Something between the inner and outer left fender?
Jwasnewski
Dawsonville, GA
Leroy
GMC SUBURBAN SLE
5.7L
Thanks, I have checked that as this noise or bump happens as the tire is elevated or bounces over a bump, crack or even a paint line on the highway. Strange.
I am going to jack it up this weekend and check it again.
Jwasnewski
Dawsonville, GA
Leroy
GMC SUBURBAN SLE
5.7L
Aries. I got them off the net from Carid. Direct fit except rear mount needed minor mod.
Scott Hathaway
US
Scott
k5 1500
This may sound strange but look at your frame really close around the steering box some times the frame will crack under the box have someone shake the steering wheel while you lay under it and look at it close do this with the engine off shake it back and forth hard
Sent from my E6910 using Tapatalk
Backfoot100
Florida
Eddie
C1500 Suburban
Carbed 350
Thanks for the info.
F-64
nyc
mike
R10 lwb
5.7 tbi stock
How do the wipers sound when on?
I wonder if your mechanic dropped a tool in the cowl and left it there.
Jwasnewski
Dawsonville, GA
Leroy
GMC SUBURBAN SLE
5.7L
Thanks for the input. I found the issue.
The upper mount bolt for the left front shock was not totally tight allowing the shoulder to slide slightly sideways when hitting a bump. The result was it bumping against the frame. A couple turns and no noise now.
I am a dinasour of sorts now at 77 trying to keep my truck really top shape. I’ll probably leave it for the granddaughter when I check out.
a couple pics.
87POPS
