Front brake dust shields
82Diesel
I <3 a gutless greasy diesel
SW, MI
Kyle
Silverado K10
6.2L
Any companies out there reproducing these (title name) for 1/2 ton 4x4? I can only locate 2WD, which doesn't interchange. My Design and style, according to the parts catalog, is 1981-83 / 84 K1 (K10) only. The design changed again. Like the steering columns did.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
I've seen em available I do believe.
Search for a gm 10 bolt instead of by vehicle. There should be much that changed as far as I know. All the 80's trucks were 10 bolts and all had the same calipers. Maybe slightly different sized rotors, but wouldn't have made big difference, probably just between k10 k20
82Diesel
SW, MI
Kyle
Silverado K10
6.2L
Good idea! I typically go by part # or as you said, vehicle. A friend of mine said they'd be the same as Dana 44?
legopnuematic
Licensed Junk Dealer
MO
Spencer
1977 was the introduction of the corp 10 bolt front, they ran concurrently with the Dana 44 front for a few years (1980). My understanding is the 77+ Dana 44s share all the same stuff knuckles out. So I’d imagine the dust shields would interchange 77+.
Not sure if 73-76 Dana 44 dust shields are the same or not as 77+
Check torque king 4x4 if you haven’t, they might have them.
82Diesel
SW, MI
Kyle
Silverado K10
6.2L
Good info! I know very little about the pre-79 trucks. Other than I NEED a C10 Olds diesel in my life... lol.
Anyways, thank you for the heads up on the company! I Found one guy on eBay who regularly has them but sell quickly.
the only hiccup is 77-80 axle shafts and by extnesion the way the seal for the outer shaft and the c click get done, and then bearings in the hub , but the spindle and hub would be the same just taking different components
Sad Sack
Nebraska
Goober
C15
idahovette
Firefighter
Weiser Idaho
Perry
K20-K10
What year were the solid ones, no sheet metal dust shields?
Moderator
I'd like to know this as well. I'd guess pre-'81, when they went with thinner glass.
hoagster
Air Force Supporting Member
California
K10, 1500
5.3l
My 73 Dana 44 has the solid ones
They cleaned up pretty good, I remember one of the members want to buy them from me!
77-80 k25 d44 for sure use em
82Diesel
SW, MI
Kyle
Silverado K10
6.2L
Yes. 4wd ones go for crazy money online... Especially SOLID! I've seen them up to $650...
RobertSC69
