frame difference
oldskool
keswick
rick
k2500
where are the frames different on a k-20 long box pick-up reg cab,vers k-20 sub i have a good frame for 1985 sub and would like to put my 1985 body on it . my frame is shot. i know the wheel base is different . but where tks rick
everything frame the motor back is different. Cab mounting points are different. Mounting points for saddle tanks are not there. Rear frame shape is different.
Dooley
North Coast
RW
V30
Apparently been done before.
Rickf
Grafton NH
1974, 1954 & a 1937
If you can salvage the cab mounts off of the p/u frame and use them on the sub's frame it should work. Use the fuel tank from the sub, make a flat bed and your good to go.
A crew cab will bolt onto a Suburban frame, but using a regular cab will require some work.
oldskool
keswick
rick
k2500
tks for the input , just thinking ? suburban frame, cut the suburban body 1 foot behind the front doors. use the back of a pick-up cab for rear window. cut a long box stepside box to fit. body lift to get the body lines to work ? i have the shop, tools, time any input tks rick
CheemsK1500
K1500
A long bed stepside box is pretty rare during the 73-87 years, you'd be looking a long time for one. I'd suggest either stretching the frame to match a pickup wheelbase or just building a custom flat bed for the Suburban frame.
CheemsK1500
K1500
With a frame stretch and lots of body work, you could try to recreate this monstrosity:
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I was told my the dad of a friend that a suburban and a single cab longbed are the same, completely swappable except the rear where the bumper bolts.
I'm guessing buy reading this that that isn't true?
CheemsK1500
K1500
There's about a 2 inch difference in wheel base length (The Suburban is shorter) that prevents an 8 foot bed from fitting correctly. I think the frame contours are little different towards the rear as well. Like others said here, things like cab and fuel tank mounts are also unique to their corresponding trucks.
Todd1960
