- Mar 5, 2014
- Kansas City, Missouri
- ryan
- r10
Not sure if this is the right place for posting but.....
I have my trans out and motor still in the truck. Trying to replace the flex plate bc teeth are missing.
Problem is... As I go to loosen the FP bolts it turns and turns the crank. I tried a breaker bar no avail, even tried a breaker bar on the front of the crank and it actually started loosing the crank pulley bolt.
How do you do this succefully? Any tricks would be greatly appreciated. I am at a loss right now.
Thought about hitting it with an impact but wasn't sure if it would help.
Dw-40 is sitting on the bolts now to help with rust but it still turns the crank...
Thanks
Ryan.
Thanks
Ryan.
